01-17-2022 07:42 AM
Hi Community,
how to change the settings to be able joing more Webex Meetings simultaneously?
I have found an officiall article telling me its not possible.
Is there any global settings where for one host more meeting license will be used?
Thank you for your reply.
01-22-2022 03:18 PM - edited 01-22-2022 03:51 PM
You can join as host more than one meeting with the older Webex Desktop App. Eventually this App will be deprecated, hopefully after Cisco allows the Webex App this same ability, but I'll link executables here for you as it's harder to find.
Also, vote up these two IDEAS and add comments so Cisco knows why this is important.
Customers- note this is one of several similar ideas if you search for "WebEx" and "multiple"
https://ciscocollabcustomer.ideas.aha.io/ideas/WXCUST-I-3292
Partners
https://ciscocollaboration.ideas.aha.io/ideas/COLLAB-I-12799
01-17-2022 05:37 PM
@krizvite the default setting for hosts is limited to host only 1 meeting at a time. As @Roger Kallberg mentioned, you can join other meetings as an attendee if needed.
01-17-2022 11:45 PM
Hi Kathy, yes for sure. This is what even the article tell us. Imagine one scenario:
Me with Webex Meeting License planning more meetings in the same time. I add as co-host other colleagues with webex meeting license. From the webex cloud I see my email/ name planing the meeting. Which license will be used for the meeting? My webex license or the license of the co-host user.
Or what happend if the co-host user has not a webex meeting license. What is behaviour of the webex cloud?
BR Vit
01-18-2022 12:43 AM
A co-host must as far as I know be defined to have the role of Host assigned in the back-end system. Again from what I know you would not be able to define a co-host for a meeting for a user that is assigned the role Attendee.
01-17-2022 07:53 AM
AFAIK it is a limitation in the Webex application. I think that you possibly could join a second, or even more, meeting via the browser "client", aka join the meeting from a web browser and not via the application.
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
