@dshumake If you're crafty you can automate this -
Here's the python I wrote for my implementation:
logfile = open('C:\\inetpub\\wwwroot\\logfile.txt', 'a+')
api_endpoint_token = '<insert api token endpoint url here>'
api_endpoint_members = '<insert api members endpoint url here>'
api_client_id = '<insert graph client id here>'
api_client_secret = '<insert graph client secret here>'
api_scope = 'https://graph.microsoft.com/.default'
api_grant_type = 'client_credentials'
def get_token():
payload = {
'grant_type': api_grant_type,
'client_id': api_client_id,
'client_secret': api_client_secret,
'scope': api_scope
r = requests.post(api_endpoint_token, data=payload).json()
api_access_token = r['access_token']
return api_access_token
def get_members():
headers = {
'Authorization': "Bearer " + get_token()
return requests.get(api_endpoint_members, headers=headers).json()
def get_photo(upn):
headers = {
'Authorization': "Bearer " + get_token(),
'Content-Type': 'image/jpg'
return requests.get(f'https://graph.microsoft.com/v1.0/users/{upn}/photo/$value', headers=headers)
for person in get_members()['value']:
try:
if get_photo(person['mail']).status_code == 200:
with open('C:\\inetpub\\wwwroot\\images\\' + person['mail'].lower() + '.jpg', 'wb') as f:
f.write(get_photo(person['mail']).content)
elif get_photo(person['mail']).status_code == 404:
logfile.write(str(datetime.datetime.now()) + ' No photo found for ' + person['mail'].lower() + '\n')
except Exception as e:
logfile.write(str(datetime.datetime.now()) + ' ' + str(e) + '\n')
logfile.write(str(datetime.datetime.now()) + ' Script Finished\n')
logfile.close()
runs as a scheduled job every day at 7PM.
You need access to the microsoft graph API for your org.
The folder that the pictures are stored in is just an directory that is served using a Webserver but local to the network. If windows you can use IIS, or Linux Apache or Nginx.
Then within the Cisco Directory Connector there's a Avatar section under configuration - just point to where it's grabbing the images.
Anyway, that's how I'm doing it, but I'm sure there's other methods!
