No Dialpad
dblevins
Using the Android or Apple Webex Teams App.
Select the calling button from the bottom of the screen
select the dialpad icon in the lower right
a screen appears captioned -Start every call with Webex.
No dial pad is displayed.
if you press the x in the upper left it returns you to the calling screen but no dailpad is present
I need the dialpad mainly to dial unlisted extensions (paging and call park are most frequent) and occasionally outside phone numbers not in my contacts. Is this caused by a setting in the App or control hub. How do i get my dialpad back?
dblevins
Got an email on my TAC case for this issue and it reads
We released a new version yesterday and this issue is fixed now. Please update to the latest version 40.12.2(1133)
I updated my App and it now works
David
11 Replies 11
dblevins
David
Goswin Weemaes
This could be related to the UX changes that were introduced in the latest release:
https://help.webex.com/en-us/8dmbcr/Webex-What-s-New#Cisco_Reference.dita_0f101eca-4aa2-4279-a78a-3169a1809a6e
Response Signature
I do have a PSTN service provider with webex calling
claudia.lievano
Any solution for this issue?? My application is updated as well as iPad/iPhone software.
dblevins
The little blue and white dial pad button is the one referenced in the original question.
I can search the numbers in the search bar but as orthers have seen you get Phone Service Unavalible
I haven’t had this problem before, but I think it’s your phone service. Not sure why you don’t have it. But here are some things you can do.
  1. Try updating WebEx
  2. Check for updates for your computer, phone, or iPad.
  3. Unconnect from phone services then reconnect (if you have it connected)
Try those if it does not work then I don’t know why you don’t have it.
I tried those and I am still experiencing the same issue. iOS and App are up to date. I see the dial pad, but when you click it, a notification pops up, and you can only click close. It doesn't pull up a dial pad. If you enter the number in the search bar and click call, it gives the error that it cannot connect to call services.
To clarify, "I see the dial pad but when you click it", I meant I can see the dots you normally click to pull up the dial pad. But no number dial pad ever appears.
Liam Morlen
  1. Do you have a dial pad button? If you tap/click on the phone on the bottom of your screen, you could see a little blue and white dial pad button.
Liam Morlen
Do you have the error “Can not connect to phone services?” Because I have that two but I have the dial pad... Try updating WebEx.
FirefoxTats
I noticed you can enter a phone number in the search bar at the top of the screen and click a call icon, but it just gives an error that it “Webex can’t connect to phone services”.
