Presence status on/off from control hub
Andrea Lippa
Hello community,
Some org ask us about the possibility to disable the user side the possibility to enable/disable the presence function, is it possible?
5 Replies 5
Leonardo Santana
That´s correct
"If you don't want people to see whether you're currently using Webex App, you can turn off your status. However, you also won't be able to see other people's status."
https://help.webex.com/en-US/article/nkzs6wl/Webex-App-%7C-Stop-Sharing-Your-Status
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Hi Leonardo,
I would like to have from control hub the option not to authorize the client to this check.
So, I can manage this as an administrator and not as a client
I didnt found any option on Control Hub to do this.
Leonardo Santana
AFAIK there is no such option in Control Hub.
Response Signature
Sorry i misunderstood your question.
I will make a research about this, because at Control Hub i did not see any option to do this.
Leonardo Santana
