Unable to assign Location administrator in WebEx Control Hub
madhusudhanam
Hello Team,
We were able to assign Location administrator Role for a User in WebEx Control Hub but unable to save that changes.
Reagrds,
Madhu
2 Accepted Solutions
Hi there,
Have you checked if you're encountering any errors while saving the changes? Typically, the control hub provides a small widget with success or failure details at the bottom right corner.
You might also want to try using a different browser or incognito/private window.
Since it's cloud-based, sometimes simply retrying after a period of time may resolve the issue.
Shalid
Disclaimer:
Responses are based on personal knowledge and experience. Consider them as guidance. Other members may offer different perspectives or better approaches. No responsibility is assumed for outcomes; discretion is advised.
Thank You, Yes it is Browser issue, after using another Browser issue Resolved.
Madhu
Blue_Bird
Hello madhusudhanam,
Perfrom the following steps to Add administrators to one location
1 Sign in to Control Hub, then under Management, select Locations.
2 Select a location.
3 In the Admins pane, click Add.
4 Type all or part of the user's name. You can add up to 5 users at a time.
5 Click Save.
Best regards
******* If This Helps, Please Rate *******
Hi there,
Shalid
Disclaimer:
Madhu
