05-21-2020 11:19 AM
Does cisco have a way to verify if a custom background has been loaded on to a cisco Webex board? 55s and 70
The only option I have is to ask end users to "check" and see if the image is correct about 50 end users. I went through and did the upload under the branding section in settings for all devices.
My thoughts are there is a way to remote into the boards Admin page and see if the file is stored somewhere on there.
Thanks in advance
Solved! Go to Solution.
05-21-2020 12:57 PM
09-07-2021 07:02 AM
I'm late to the party on this one, but another way you can approach this (when you want to do one-off changes) is:
Within Control Hub > Devices > Device Web Portal
Under Personalization, you can see what's currently visible on your displays/touch pads for that particular device.
05-21-2020 12:57 PM
05-21-2020 01:22 PM
Thank you that is exactly what I was looking for Mike!
