Webex Call Local PSTN Gateway Dial peer Configuration
Brandon Rebbe
I have an ISR4321 with Cube licenses and i already have it registered to my Webex Calling Location and online.
The examples for Dial peers in the deployment guide refence sending the calls via IP to another service or gateway from the ISR Cube.
Our setup is an ISR with a local T1 card in it that will replace our existing 2901 that it MGCP to CUCM.
My question is: Can i have the calls routed to the local T1/PRI port or do i have to keep my old 2901 setup and the Cube just forwards the Calls to it? The example shows IP PSTN and i need to adjust the dial peers to use the local Interface i think.
Brandon Rebbe
I think i found the solution on the Cisco Japanese Support Community. This document shows the Dial peer statements needed for the local gateway to have a PRI instead of forwarding it on to another IP ISP.
https://community.cisco.com/t5/%E3%82%B3%E3%83%A9%E3%83%9C%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3-%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88/webex-calling-%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%8...
dominic.fidler
Thanks for linking this doc.  This is the single, most helpful document I have every seen from anyone in cisco.  clearly stats out all the steps in an easy to follow method and something I could not find.
this doc got this setup working for me first time!
Brandon Rebbe
