WebEx Hybrid Connector upgrades
AseemAnand
Hi Team,
Just wondering if somebody can provide recommendations for the connector expressway with all the pre-checks and post-checks?
Aseem Anand
palbhard@cisco.com
Hi Aseem,
For the Supported version for Expressway Connectors, you can refer to the below document
https://help.webex.com/en-us/ruyceab/Supported-Versions-of-Expressway-for-Cisco-Webex-Hybrid-Services-Connectors
for Existing servers, its 8.11 and above. for new installations, its 12.5
For connectors to be upgraded, you can follow the below process
https://help.webex.com/en-us/lq7r0c/Upgrade-the-Connector-Host-Expressway-used-for-your-Hybrid-Services
For Automatic upgrades:
This feature only supports one scheduled upgrade time for each cluster. If you have a single Expressway-C, you will experience a brief outage while an upgrade occurs. We recommend that you schedule a convenient time for upgrades (for example, after hours).
https://help.webex.com/en-us/nhhoxf6/Manage-Installations-and-Automatic-Upgrades-for-Cisco-Webex-Hybrid-Services-Resources
Hope this helps!!
Pallavi Bhardwaj
mtabrez
