Webex Meetings 39.9.3.125 screen sharing broken in MacOS 10.15.1
jasonm002
Webex Meetings (the app that launches after you join the meeting from the calendar invite) version 39.9.3.125 screen sharing appears to be broken in MacOS 10.15.1, if you share the entire screen the remote viewer just sees the desktop background, and if you share a specific window (terminal in this case) the user reported a similar thing.
The same version on MacOS 10.14.6 works fine.
vasank
Curious, did you set the permission to allow for Screen Recording in Security & Privacy  ? I had the same issue this morning and once I enabled it, and launched another meeting it works.
Thank you,
Vasanth
The app should probably display a dialog box that prompts you to enable screen sharing if the permission has not been granted -- for every time that you try to share your screen in the app and the permission is still not granted.
That said the permission was unchecked on my system so that was probably it. Thanks.
