Webex Room Kit compatible with an external touch monitor?
MoshPitches
Hello there.
My company is about to buy a Cisco Webex Room Kit and told me to check out whether it is possible to use the Room Kit with an external touch monitor (not that little tablet).
The Room Kit is supposed to be mounted on top of a TV. What if that TV supports multi-touch controls? Will it be possible to use this touchpanel with a Room Kit?
Thanks in advance for helpful answers!
Vaijanath Sonvane
The external touch screens/monitors are not going to work as touch panels. They do not have necessary software, hardware and compatibility to with Cisco Webex Room Kits.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
