05-08-2022 10:16 PM
I am not sure if this was something that was there earlier. I want to know if there is a way to filter out detailed call history records from the control hub analytics page based on a time range, and also if I can specify the time zone to which a call belongs?
I was told by a user it was possible earlier but it seems that the filters are only based on call direction, type, classification & location.
09-21-2022 06:35 AM
At the moment, all times are in UTC time, and it is not possible to select a specific time of day on the dashboard in Control Hub.
However both features are under consideration for future release.
An export of the data can be interacted with via the Reports section which will give you a CSV file with raw data, if this helps address your use case.
05-12-2022 11:25 AM
The cdr view also takes care of the whole analytic's page date range filter. Ie. in the upper right of the page, you have the date range selector, it also affects the cdr table
05-12-2022 06:25 PM
dtibbe,
Where in the portal is this? By CDR did you mean call detailed records. I'm assuming it's on the reports section. If so it still gives you to filter by date but not the timezone and time. Correct me if I'm wrong.
05-17-2022 10:23 AM
I was referring to this: https://help.webex.com/n0rlwxe/, section Calling, detailed call history.
As the description shows, all calls are listed in UTC. That's also the case if you have access to the CDRs via SFTP (former Calling SP partners), they also have UTC plus another column for the UTC offset from the user's location
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
