Disable Call between extensions in same location
HI,
I'm in a scenario where we must disable call beetween extensions in same location, I didnt find anything about this "feature" on go learing webex.
The context is a store where call are disable beetween department
Question:
Where we can definie prefixes list for call type?
dtibbe
The screenshot you shared allows you to disable all internal calls, ie. all calls within your organization. There is no option to just disallow calls in a single location, but to allow all other calls to other locations or such.
What do you mean by "prefix list for call types"? You may just specify a location code, but there is no dedicated prefix for "national" or "premium rate" calls..
dtibbe
