09-15-2022 11:51 PM
This is a question about DeskMini's macro function.
Can I use all the functions that were available in the DX series?
The features I want to use are "Quick Dial" and "UI Extensions Editor".
Another question is, do I need a device license to use the DeskMini?
Solved! Go to Solution.
09-19-2022 09:30 PM
Yes, the Desk Mini supports the UI Extensions and macros so you can set up features like quick dials or other functionality the same as you can on the rest of the newer Webex Devices.
Please remember to mark helpful responses and to set your question as answered if appropriate.
09-19-2022 09:30 PM
