Is there a way to use MS Teams Cast to share content on a Cisco Room Bar? If not how are people sharing their screen without connecting to the device using the Webex App and the the ultrasound capabilities.
Hi allI've got a Board Pro 75 in an existing installation. The client has some other rooms with third party whiteboard screens, and in those rooms we have a "UI Extension Panel" page with a "Show Whiteboard" and "Hide Whiteboard" buttons. Those butto...
I'm having a issue with getting my activation code to work with my desk phone. When I click continue after entering my code, I get this message (Verify Your Internet Connection). Currently my team is trying to get webex calling working and want to us...
I've tried this with a couple of RK EQ codecs with a Quad Cam but the audio is sent to the TV instead of audio output through the QC. I have tried HDMI extenders because of the distance and only the TV would output audio. I then found out that ARC ...
Hi,I was wondering if anyone knows if Unify/ Mitel Openscape IP55G desk phones can be either flashed, changed or modified to be compatible with Webex Calling (MMP) or SIP based Unify/ Mitel Open-scape PBX environment is compatible with Cisco Webex Co...
We have 6 spark units at our organization. They are linked to our phone CISCO phone system. We are swithing to MITEL phones (not my choice!!) Can these units be disconnected from the phone system and be used on a license that does not require a p...
Hello,Does Webex board 55 support USB passthrough ? thanks
Is it possible to connect a Room Navigator to a Desk Pro? I have an executive that does not like to lean towards the camera to shut it off as they say it looks unprofessional and would like to do this with either a Touch 10( EOL) or Navigator.
Hi Team, We are facing some issues on all Webex devices, we are using Cisco Desk Pro ,Desk, Room kit ,Room Bar the device license has already assigned, but when ever we are turned off the device the next day once turned on the device it is showing c...
Working in a relatively complex space with multiple PTZ4K cameras, multiple Ceiling ceiling mics and multiple HDMI displays running into a EQ Codec in a tricky location (due to requirements for screen sharing via USB-C, access to the navigator etc.) ...
I just bought a Cisco 730 Headset. I've installed the latest firmware (which took a log time to install comparing to other brands) this are the list of problems that I've noticed so far.Clamping force in the ears is too strong to the point of becomin...
Hello, I'm trying to provision a Room Bar in MTR mode, but the Microsoft Teams Room Experience option does not appear in the initial setup. The option is not available on a specific device. The room's software version is RoomOS 11.15.1.6 ab740596da6,...
The Settingsmenu shows the HDMI-Output. But there is no Signal.Can i use the HDMI-Output or is it still not usable?Magnus
I've went through the available documentation of the new Cisco Table Microphone Pro but I could not find if the microphone UTP/LAN cable can be connected to the same LAN of the Room codec or if it needs to be connected to the private LAN of the codec...
Hi, I would like to know if the network settings for the navigator are available when we have the navigator directly connected to the codec?when the navigator is connected to a switch I can find on the navigator the network settings for both the code...
Subject | Author | Posted |
06-11-2025 09:51 AM | ||
05-26-2025 03:20 PM | ||
04-24-2025 07:40 AM | ||
04-10-2025 02:22 AM | ||
04-03-2025 09:32 AM |
