Webex Devices
I purchased a few 8811's and when I plug them into the network the activation code screen comes up. Will not accept multiple different activation codes, nor will it register via MAC.Get's ip address as expected, (same as the other 120 phones I have i...
Jacobb_S by Level 1
  • 1586 Views
  • 2 replies
I have a room Kit that is not connecting to the content source.  All connections are good and  the PC producing the content is functioning.  Sometimes if I send content from another room to this codec and then reverse the content it will connect.  Is...
Hey folks -A recent update to Webex on my Mac seems to have made it impossible to use my Blackmagic Decklink capture card with it.  I have a 2019 Mac Pro (tower) with a 4-port HDMI BlackMagic card in it.  Formerly, the card's 4 ports would show up as...
JasonVP by Level 1
  • 432 Views
  • 0 replies
Hi All   We had configure MS Teams with Webex using with CVI in controlhub, when i schedule meeting on the O365 web we are getting sip uri information on the meeting body but if i schedule meetin on MS Teams app sip uri information is not available i...
KY_ by Level 4
  • 487 Views
  • 0 replies
I see in the latest Webex Board Pro admin guide it has a 2nd network port with Touch and Camera icons on it. Does this means you can connect the Webex PTZ 4K camera to the Board? Which input  do you then use for the HDMI output from the camera? The H...
gfolens by Level 4
  • 901 Views
  • 0 replies
I'm hoping to receive some guidance on how to fix this issue.  I have a staff member that using a Pixel 6 as a work phone.  We recently moved to WebEx from mobility.  After the upgrade the member can no longer get voicemail on their cell phone. (imag...
dalexis by Level 1
  • 460 Views
  • 1 replies
