CS-KITPLUS-K9对接第三方中控的代码表?
Shark1990
CS-KITPLUS-K9并没有RS232串行接口,如何与第三方中控主机的RS232串口对接,是通过在Codec Plus上的USB接口插USB转RS232转接线来实现吗?
另外请专家老师告知下串口代码表,谢谢!!!
Wayne DeNardi
You can connect a USB (Type A) to serial (D-sub 9) adapter.  Most USB to serial should work but Cisco recommends the UC232R-10 USB to RS232 (FTDI) adapter for best compatibility.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Thank you for your reply! Can you help me to provide a code list for the central control instructions?
Detailed instruction code is required to write instructions into our central control host.
