Enabling One Button To Push to Zoom Calls
jomin
Can anyone help to enable One Button To Push for a Workspace to join in a Zoom Meeting.
As of now we have enabled this for Google meet.
PJMack
Level 7
Level 7
As Jonathan mentioned - you need a SIP URI (which is a gateway service) to join a Zoom meeting with a Webex device. Google meet and MS Teams support WebRTC, but Zoom does not. Usually it will be "meetingid@zoomcrc.com". If that SIP URI is in the meeting invite and the endpoint (or person it belongs to) is invited you should get OBTP, I have done this successfully.
Jonathan Schulenberg
With Hybrid Calendar, correct? Does the meeting invite have a SIP URI in it?
My understanding is that OBTP works with Zoom SIP URIs unless the host/admin has customized the template in a way that would break the RegEx match.
