How to disable share preview of Codec Pro
Paul Freiberg
Hi all,
we need to disable the share preview of the Codec Pro, during a call.
Because the preview is visible on the screen all participants can see it.
Does anybody know how we can disable that "feature"?
Best Regards
Paul
Check the Video Input Connector [1..4] PresentationSelection setting. (Settings - video - input connector [1..4] - PresentationSelection)
If set to Autoshare it will automatically share your presentation as soon as you connect the cable.
