06-24-2022 06:15 AM
I am trying to make the Webex device (Webex Room Kit Pro Precision 60) to allow Webex systems to connect a Google Meet without asking but even I followed the procedure, when I joined a meeting, still requires for a host accept the device to connect.
I contacted Webex and Google but nobody hasn't helped me out.
Google told me they didn't recommend to use third party device to join a Google Meet and they didn't support.
I need someone's help.
Solved! Go to Solution.
07-22-2022 03:47 AM
Unfortunately you are asking cisco forum a question only google can answer. The own the meeting platform and how users authenticate to meetings. A few years back the room kit registered to CUCM did the same thing when joining a webex. If the endpoint was first to the meeting Webex would announce "if your the host please enter the host pin". Then as devices moved to webex edge and eventually the cloud Webex allowed devices it trusted (i.e. cloud registered room kits, or webex edge registered) to join without being held in a lobby instance.
The ask you have would be a feature controlled by google meeting platform. Sorry this does not solve your issue.
07-22-2022 03:47 AM
07-12-2022 12:49 PM
You're missing the Interoperability token. It needs to be set in Google under your account domain for the room kit to join meetings without needs the host's approval.
07-13-2022 06:11 AM
Even though I added a token and status shows as interoperability taken active but still needs to wait to be admitted as a guest.
A token from test domain works but a token from production domain doesn't work.
07-18-2022 10:44 AM - edited 07-18-2022 10:48 AM
Have you followed below procedure:
07-18-2022 11:10 AM
Thank you for the instruction. I have done that already but still not working. A token from test domain worked but from production didn't work.
06-25-2022 02:30 AM
I’ve never used Google meet, but isn’t it the normal operation to put unauthenticated, guests or whatever this is called on the Google end, into a lobby for the host to let them into the meeting? This is anyway how this operates in other meeting platforms that I’ve used.
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
