Room Kits Room OS - Failed setting passphrase. Error: The passphrase
garryemiller
Error in reusing passphrase across multiple endpoints - even if User Management Password Policy settings are all at "0"
  • The passphrase is commonly use
Anyone know why the Passphrase settings do not seem apply?
Jonathan Schulenberg
Individual endpoints are unaware of what you have set on other cloud-reg or cloud-aware endpoints in your environment. There is a built-in list of exceptionally bad passwords that won’t be accepted though, eg “Cisco123” or “password.” Does the endpoint accept a strong randomly generated password?
That is what I would expect about awareness on other devices.. It does accept a random generated psswd which has a minimum of 8 characters  - perhaps the issue is using less than 8 even though there is No min set on codec?
Yeah. I'm (thankfully) not in InfoSec but I believe that to be considered trivial to break at this point. For local non-expiring credentials I'm seeing a lot of org policies require 16+ characters these days.
