RoomOS 11.9.2.4 calling disabled.
wansupport
I have upgraded my room kit device to the latest OS which is 11.9.2.4 which is released on November 9, 2023. After upgrading I have some problems connecting calls - calling disabled and when someone calls the device extension it shows busy. Any idea what the problem is? Is it an OS bug? When I rollback that OS issue is automatically resolved and my calling is enabled.
Please advise me about this. Thanks
RITT
Had this problem when upgrading a brand new out of the box Room Kit to room OS 11.20. Registered on premises to CUCM all OK but room kit main display showed "passphrase not set, calling disabled". Believe it or not setting a password on the room kit allowed the incoming calls. Pervious versions didn't do this.
While it is possible for things to break with firmware updates, completely disabling calls isn't usually one of them, so there is likely another configuration issue somewhere that is being affected by the update.  It is hard to provide much detail on what your issue could be without further information on your environment, like what control platform are you using?  Are the calls/registrations H.323 or SIP?  Are the devices showing as registered correctly on the endpoint's web interface?  Are there any errors showing on the device?
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
