Sharing on a Cisco Room Bar using MS Teams
scooter1970
Is there a way to use MS Teams Cast to share content on a Cisco Room Bar?  If not how are people sharing their screen without connecting to the device using the Webex App and the the ultrasound capabilities.
If you are running one of the later software versions on the Room Bar, you can go in to the settings on the device and enable Miracast and/or AirPlay.  Either will allow you to wirelessly transmit content to your Room Bar (assuming the device you are using is on the same wireless network, or at lease one that can access the codec on the required ports).
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
