change line Lable on Webex device
I want to customize the default line label on the device using API
there is API to do it ?
under device configuration
Configured Lines
rikardkrvaric
Did you check the Developer.Webex.com site?
This might be what you're looking for:
https://developer.webex.com/docs/api/guides/webex-calling-provisioning-apis
Yes, but I didn't find line label change using API
I was thinking this was Caller ID..
What does the Label refer to?
