Enable Kiosk mode through API
Raffaele Lagana
Hello, I just updated a webex board to the new roomOs Version 11 to test the kiosk mode. Unfortunately i noticed, that there is no xapi command to enable/disable the kiosk mode or set the kiosk url over a macro skript. When will this feature be available? Or is it already and i cannot find the correct command. At your roomOS documentation (https://roomos.cisco.com/xapi/) i cannot choose xapi version 11 yet, when will the docs be updated?
Raffaele Lagana
Hello, currently this is not possible through API, you may add it as a feature request here: https://ciscocollabcustomer.ideas.aha.io/ . Our product managers can then assess and provide feedback.
Raffaele Lagana
