10-01-2024 03:10 AM
Hi Team,
I am using below payload for getting access token
https://webexapis.com/v1/access_token
with below payload
10-01-2024 06:52 AM
@prashant-chinchkar note, that if the Integrations scopes changes since the creation of the access token / referesh token pair, you would need to create a new token to have them applied. If you authorize the Integration again and get a new token pair, do you have the same issue?
10-03-2024 02:54 AM
@Janos Benyovszki Does this mean My integration should get authorise again with meeting:admin_config_read meeting:admin_config_write?
When I created a integration I chosen meeting:admin_config_read meeting:admin_config_write scopes.
