Read messages from Webex room
vmorilla
How can I export the conversation of my Webex team rooms, in which Im involved? I tried to use it with my custom bot, but is not possible.
dstaudt
Webex Teams bots will only be able to access messages that the bot itself sent, or messages in which it is '@' mentioned.
You can try using the temporary 'personal access token' you can retrieve from the Teams docs pages here (be sure to log in first:) https://developer.webex.com/docs/api/getting-started
However for production use, you will want to implement an OAuth integration, allowing the user to login via Teams OAuth so your app can get a 'real' user access token, which should be able to retrieve all messages in rooms where the user is a member: https://developer.webex.com/docs/integrations
If you need to archive messages for other/all users, note there is a 'compliance' role and application pattern that should be helpful: https://developer.webex.com/docs/api/guides/compliance
