Webex Calling: Webhook filtering by Calling number
YukioHashimoto
Community Member
For webex calling calls, we would like to send webhooks only when call is received from specific phone number.
Example:  Send webhooks only when calls are from +819000000000.
Case 1. A calls B:  webhook is sent
  A: Calling (Caller) number: +819000000000 (mobile)   <-- match with filter
  B: Called (Callee) number: +81566667777 (webex calling, webhook registered)
Case 2. C calls B:   webhook is not sent
  C: Calling (Caller) number: +81111112222 (fixed phone)  <-- no match
"address" filter parameter can be used for webhook filtering by calling number +819000000000 (mobile)?
If not, what are appropriate ways to achieve this?
https://developer.webex.com/admin/docs/api/guides/webhooks#filtering-webhooks
Janos Benyovszki
@YukioHashimoto using the address filter you should be able to limit webhooks to calls to a particular number. So mobile number should be valid here. Please test it and see if it works.
