Webex Meetings Widget via CDN
Janos Benyovszki
Question
Is it possible to use the Webex Meetings Widget in an application without using node.js/NPM? The docs only contain instruction for using npx to install it but not how to use it via CDN.
Janos Benyovszki
The Webex Meetings Widgets are currently not available via CDN, as mentioned in the documentation:
Meetings Widget is available on NPM  with no support of distribution via CDN at the moment.
We do have plans to make it available via CDN, but there is no concrete ETA for it yet.
Janos Benyovszki
