@rremelgado , did you check the "Usage Report" you can generate from your Webex homepage?
On the next page you can click on "Usage Report", and then select a specific date range. Once it has generated the list of meetings that took place within that date range, you can click on the one you are interested it. This will then give you a complete list of all participants with their respective start & end time (and duration).
