el 10-23-2020 06:48 AM
According to the road map v40.10 should have introduced mp4 formats for recordings but I don't see it anywhere. Anyone has head anything?
thanks,
koorus
el 10-25-2020 11:27 AM
@koorusbookan , Webex Meetings generate MP4 recordings. Customers have the choice of ARF or MP4 recording in Webex Events. ARF is the only recording format in Webex Training.
el 10-26-2020 06:19 AM
Yes, I know. I'm talking about Training.
el 10-23-2020 08:54 AM
Usually, the upgrade will happen on a particular day, and enabling the feature enhancement a week or two later.
https://status.webex.com/maintenance?lang=en_US
We are on cluster AW...
October 22, cluster AW got upgraded to 40.10 (Green color)
October 27, cluster AW will get feature enhancements... (Purple Color)
Find your cluster name when you login to your companyname.webex.com administrative portal.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
