cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Need to flip document camera image
karen.yip
I am using a HUE document camera. The camera sits at the top of the page so the image appears upside-down. Although WebEx has a "mirror" tool (horizontal), it would be VERY useful to have a flip tool (vertical) as well. I would rather control the image within WebEx than to need to open the document camera software and share-screen of that view vs, have direct HD image "broadcast".
What can I do about this?
thanks
Karen Yip
2 RESPUESTAS 2
Matt_Wynd
Yes, thank you.
This does work to flip/mirror the image but I was hoping to not need to share screen of the HUE software screen but instead make it directly feed to WebEx in that orientation.
Yes, this is the workaround which works perfectly well except I think it loses some resolution and clarity in the process.
thanks
