177
Highlighted
Beginner
How to Move Floating Panel When Sharing Content
Hi There,
I hope someone here can help. Is there a way to move the floating panel window which appears at the top of the screen when you share content? I want to move it to the bottom of my screen because it's really annoying when I'm trying to access different window tabs on the browser. (See screenshot attached)
5 REPLIES 5
Highlighted
Beginner
Hi @AnonymousAngie ,
Can you try to select the "6 dots" as in my screenshot below and move the floating bar in the area that you want?
Highlighted
Beginner
Thanks, Jeff. The dots do allow me to move the panel horizontally, but unfortunately, I cannot move the panel vertically to the bottom of the screen.
Highlighted
Collaborator
I totally agree - and you have spurred me on to post the following idea
https://ciscocollabcustomer.ideas.aha.io/ideas/WXCUST-I-1320
PLEASE VOTE FOR THIS SUGGESTION
RedNectar
aka Chris Welsh
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
Highlighted
Beginner
Another suggestion is to hide the sharing toolbar:
Windows: Ctrl+Alt+Shift+H, select OK (unhide with ESC)
Mac: Command+Option+Shift+H, select OK (unhide with ESC)
Highlighted
@KirstenM ,
Well there ya go. A well hidden (and so intuitive ... NOT) Command+Option+Shift+H key combo.
I wonder why Cisco had to hide so well as to NOT include it as an option when clicking the ellipsis (...) menu!
I have modified my suggestion to reflect this.
RedNectar
aka Chris Welsh
Content for Community-Ad
