02-05-2022 11:23 PM
We are discussing to buy the good WebEx kit CS-KITP60-K9, we wanted to ask if it also supports the Zoom meetings too.
Solved! Go to Solution.
02-07-2022 07:22 AM
Hello Mohammad,
Yes you can join meetings from a Webex Room Kit, but the host or the attendee will need to have a Zoom CRC (Conference Room Connector) license, this is due to the fact that Zoom is not based on open standard and cannot support standard SIP devices natively.
You can install this macro for easier Zoom join experience:
And Zoom CRC information:
https://explore.zoom.us/en/products/zoom-rooms/room-connector/
Hope this helps.
02-07-2022 07:22 AM
Hello Mohammad,
Hope this helps.
