embedding a WebEx meeting
I'm wondering if and how you can embed a WebEx meeting in a Learning Management System.  And if you can, where do I find the code?
Thank you!
5 Replies 5
Mike_Brezicky
Yes, you are able to integrate into a LMS.
Please check here for details on the Education Connector.
https://help.webex.com/en-us/n77zrcq/Control-Hub-Site-Administration-Install-the-Cisco-Webex-Education-Connector-in-Your-Learning-Management-System
Thank you, Mike.  My learning management system is through my AMS (Association Management System) MemberClicks.  It is not one of the platforms listed.  Is it still an option for me?
https://www.memberclicks.com/learning-management-software
It still might be supported. The Webex just ties into the API of the LMS platform. Unfortunately, if its not on that document, you may need to reach out to MemberClicks for information regarding their API's/
Hi Mike - sorry to keep bugging you!  They told me that their LMS doesn't have LTI so the only way to link to Webex within it is to embed the code...is there anyway of doing this?  I'd like to stick with WebEx for an upcoming virtual conference I'm having, but really need this capability.
That would be getting into the API and doing a custom setup. I am sure its possible, but you might need a partner or third party to help with the integration.
