How to disable AppHub in Webex (formerly Teams)
tpolowy
My organization would like to disable the AppHub functions is Webex Teams. Is this possible? (I've attached a screen cap of the icon in the client.)
Thank you.
Wade H.
This can be disabled by your Webex administrator from Control Hub
From Control Hub (admin.webex.com) click "Messaging" from the left navigation menu. Scroll to the bottom of the page, there is a section for "Webex AppHub" which has a toggle button to enable/disable the AppHub icon in the client.
emajcic
Hi All,
I think it's moved.
Under Management, then Apps, then General. the first option; "Enable launch of Webex AppHub from Webex". Also Cisco webex appreciate you update the following help page. It's not right
Remove the Webex App Hub Icon from Webex
tpolowy
Thanks very much!
Wade H.
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
