I have troubles with webex teams
ken02043
I downloaded this program on my computer and used it.
But Webex teams showed me error message when I logined .
when i logined Webex teams, Webex teams showed the messages "The account on the server is incorrectly configured" or "I can't patch the server lists"
I have to solve this problem to take a lecture.
please tell me how to solve this problem
Goswin Weemaes
@ken02043 , did you try running the Media Test to see if network is correctly configured?
https://mediatest.webex.com
Response Signature
Fritz_H
@ken02043
Depending on the type of account you have, you may want to try to log on to the Web-Client of Webex-Teams.
This may perhaps help to find out, if the issue is related to your computer/the client-Software on your computer
OR if the issue is on the "other end".
https://web.webex.com/
or
https://teams.webex.com/signin
I tried log in at "https://teams.webex.com/signin"
It was fine. It's alyways been fine.
But I want to use "WEBEX TEAMS CLIENT"!!!!!!
Is there any solution?
@ken02043
I think, aggressive writing is possibly not the very best option when asking for support.
Your succesful test with the Web-Version of Teams showed that the issue is not caused by some Cloud-Config on the Cisco-Side.
You may also additionally check, if the Smartphone/Tablet-App is working fine.
If this also works, I am pretty sure, that the Computer-Setup needs some attention.
