Does the Teams meeting invite from the other organization have a “Join on a video conferencing device” section in it?
If it does the codec is attempting to use the host’s CVI subscription through Cisco or Pexip to join the meeting. If that’s broken it will fail to join (e.g. the host org discontinued their subscription but failed to properly decommission it in their tenant). You could work around this by using the Microsoft Teams button in RoomOS 11 instead of OBTP and entering the meeting ID & passcode instead of the VTC tenant key and access key.
If not then the codec thinks your Webex Control Hub tenant has CVI configured and it must not be working. Cisco’s VIMT implementation of CVI now supports cross-tenant joins, so the codec will attempt to leverage that if the received invite doesn’t have CVI join details. If you’re paying for VIMT licenses on your Collaboration Flex subscription you may want to review the configuration - especially the authorization into your M365 tenant.
The codec will default to a WebRTC join in the total absence of CVI capabilities, if it’s enabled.
