02-09-2022 08:21 AM
The "new" Webex App works great on our Windows PCs at my workplace which I use a lot to join and start meetings. I downloaded the mobile app and attempt to join a meeting but then get prompted to download Webex Meetings as well. So you have to have BOTH on a mobile device for Webex App to work correctly? Is there a fix coming that will not require Webex Meetings to be installed like on our Windows PCs? Thanks.
Solved! Go to Solution.
02-09-2022 11:45 AM
Currently, that is the way it is.. Cisco is working on merging those apps as well, but I am not aware of any ETA..
02-09-2022 11:45 AM
02-10-2022 08:18 AM
Ok, that is good to know. Hopefully Cisco comes up with a resolution soon as our end users will not want to download 2 apps just so they can use Webex app to join meetings while on the road using their phones.
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
