07-31-2020 10:21 AM
Why cant we format text like this in the Webex Teams desktop app?
I've wanted this for some time now, it gives a quick easy way to point out a correction and there are plenty of humorous ways to use it too. What do you guys think? Would this be of use to you?
Solved! Go to Solution.
07-31-2020 11:46 AM
Hi Cody,
Thanks for posting here in the Webex Community.
I checked to see if anyone has submitted it in our User Community Feedback Portal, but I couldn't find a similar request. I recommend you Submit the Idea, which goes straight to our Product Management team for review. You will receive live email updates when the status of the idea changes, whether it be up for consideration, future planning, etc. You can click on the Share a product idea tab at the top to submit your idea!
07-31-2020 11:46 AM
Hi Cody,
08-19-2020 06:30 AM
08-19-2020 06:32 AM
Hi Cody,
The design of the community changes every now and then. The share a product idea link is now in the blue dropdown on the side of the screen as seen in the screenshot below.
08-19-2020 06:34 AM
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
