Global Shortcut - Mute/Unmute
alternator
Is there a setting in Webex Meetings to enable Global Keyboard Shortcuts?
I use Ctrl + M to mute/unmute my audio but it requires the Webex Meetings window to be focused.  I'd like the ability to use this shortcut even while not focused.
Zoom allows shortcuts to be customized and made global (see attached)
Vaijanath Sonvane
Cisco Webex Meeting Center has fixed shortcut keys which can not be customized and doesn't work when the Webex Meeting window is minimized. I think this is going to be a new feature request which you can open at:
https://ciscocollabcustomer.ideas.aha.io/ideas
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
Thanks @Vaijanath Sonvane, I've put in a feature request.
If anyone else would like this feature, please be sure to take a second and click the vote button on this page:
https://ciscocollabcustomer.ideas.aha.io/ideas/WXCUST-I-41
