How to check if Video Integration for MS Teams is active
gfolens
Level 4
Level 4
Is there a way to see on the Webex Control hub if the Video Integration for MS Teams is active?
chrisconnolly
For CVI on WCH you can goto Services->Hybrid->Video Integration. There should be a green dot that says operational if all is well. You can click edit settings if you want to see some additional info.
Not really. On my partner account I do not have this behaviour for CVI enabled customers. No green dot and no edit option. Only Setup.
So I think this is a issue for Tac.
