01-21-2021 06:44 AM
When I'm in a call I can add a participant. Can I add more than one? It there a limit in the number of participants?
Solved! Go to Solution.
01-22-2021 07:23 AM
Yes, you should be able to add multiple guests to a call. If this is a simple "Webex Call", I expect you can add up to 200 participants assuming you have the appropriate host license. If not, I think the limit is 25. Err - maybe 100 now, according to https://www.webex.com/pricing/index.html
Another possible limiting factor is your organization's calling setup. If using Unified CM calling, the participant limit on a call may be controlled by the CUCM device/line configuration.
01-22-2021 07:23 AM
01-22-2021 05:21 AM
Honestly I never tried that before, but in case there is no other limiting factor, your host-license-level will set the limit - I guess.
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
