C40 Endpoint & Callway Multisite
Joseph Chambers
Beginner
Beginner
Do you still need to buy the multisite option for any endpoint that will needs more than 1 more participant?
wbroeder
Beginner
Beginner
Hi Joseph,
The C40 requires the multisite option to be purchased for multipoint to work. Multisite with allow capability for up to four sites total. The hosting C40 and three additional endpoints.
You can find the installed options on your endpoint, it is visible on GUI on the System Information tab, under Installed options.
You will need multisite features and a premium subscription on callway, for three concurrent calls on the C40.
