Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
7361
Highlighted
Advocate
Question: Can I dial SIP URI from my Callway?
Can I dial my public SIP e164 number (example)  +1408XXXYYYY@wwww.zz from my Callway ?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Contributor
Re: Question: Can I dial SIP URI from my Callway?
is it a video endpoint? Or a voice endpoint?
if its voice just dial the E164 DID and you should be good. If its video - try dialing 1408xxxxxxx@domain - does that work?
4 REPLIES 4
Contributor
Beginner
To see information about supported Cisco Callway calling scenarios, refer to the
Cisco Callway Calling Scenarios document at https://supportforums.cisco.com/docs/DOC-14892.
Advocate
Hi Maulik,
Its a video endpoint .
Beginner
You should be able to dial 1408xxxxxxx@domain.com and connect successfully with video & audio. For this to work, the domain does need to be publicly registered & reachable.
Sridhar
