Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
2692
Martin Oles
Beginner
Webex on workstation crash when connect to local audio
Having Windows7 workstation Webex started to crash, when I am trying to choose local computer audio. When I choose "call me", then there is no problem. Do you have any suggestion, where to look for reason? It might happened after some windows update. I have tried to remove Webex and then installed again, but no luck.
The program atmgr.exe version 3207.0.1709.2600 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
 Process ID: 20f4
 Start Time: 01d35863851683cc
 Termination Time: 26
 Application Path: c:\programdata\webex\webex\t32_umc\atmgr.exe
 Report Id: e8652791-c456-11e7-8293-9e84f047e851
Thank you.
0 REPLIES 0
