Hide "WebEx-ID Login" when SSO is enabled
etamminga
On a WebEx Meetings site that has SSO enabled, can we hide the option to login with a WebEx-ID and just only have the Office 365 login visible? (this site is managed in control hub)
Erik
Yes, for the button to disappear please uncheck "Sign In" under third party integration for 365. Please follow the article where you can find that setting in admin portal.
mtabrez
Please verify if 365 sign in is enabled for user for your site, in the admin portal. This is under common site setting>third party integration.
https://help.webex.com/en-us/4c30cx/Configure-Third-Party-Integrations-for-a-Webex-Site-in-Cisco-Webex-Control-Hub
https://help.webex.com/en-us/k6j1db/Configure-Third-Party-Integrations-on-a-Webex-Site
As you can see from the screenshot, 365 login IS working fine, no problem with that.
We want to HIDE/DISABLE the WebEx login and only have the 365 login available. Possible?
Erik
Hi.  I have the same question but do not see the solution.  If I uncheck the box then the O365 login goes away.  Were you able to figure this out?
