04-08-2020 11:50 AM - last edited on 05-04-2020 01:49 AM by Cole Callahan
Is it possible to use a mobile device and a PC together in the same meeting? Basically I don't have a webcam, and I would like to use a tablet as a webcam, but at the same time I also need to share the PC screen.
Thank you.
Solved! Go to Solution.
04-14-2020 01:30 AM
Yes, you will appear as two different participants. Create the event from your main account and send an invite to another email you can access from your device. You may have to use Lock Focus as the host to toggle the camera. You should only use one for audio as you will get echo for being on both at the same time.
05-08-2020 08:27 AM
Yes, it is possible to join a same meeting from PC and mobile device. From mobile device, you can join as a host or attendee.
04-14-2020 01:30 AM
04-08-2020 01:05 PM
I guess the following should work:
host the meeting with your main Device - the PC (?).
Then join your own meeting as a guest, using the tablet.
To be able to join as guest, you may need to log-off from your webex-account on the tablet-app.
04-09-2020 02:28 PM
04-09-2020 03:07 PM
Thanks, good input. I guess you wanted to target it to @SalvatoreT3
Since he mentioned that he wants to use a tablet as webcam, I concluded that he is using a "Desktop-PC"
which usually lack a webcam and a microphone...
but your are right: better safe than sorry.
04-08-2020 04:17 PM
I will be a guest with both my PC and tablet.
04-09-2020 04:35 AM
@SalvatoreT3
I see. It should be even easier then.
If I was in that situation, I would try to use different guest-registrations:
Webex usually asks for a Name (to be able to display something useful in the Participants-List)
and an eMail-Address (in case all participants receive a recording etc.. after the meeting).
Perhaps use "Salvatore" und "Salvatore-Tablet" ?
just to avoid misunderstandings..
kind regards
Fritz
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
