1042n configured as a WGB in a Lightwieght Envorinment
cespangler
Here is what I am attempting to do.
1.  I have a 1042N AP cofigured as a Workgroup-Bridge attaching to a Lightweight Access Point.
2.  LWAPP AP is on a 5508 series Controller.
3.  I have MAC Authentication configured through an Ciso ACS box running 5.2 code. And that portion is working.
4. I want to lock this WGB down even further with a second layer of security. I am thinking WPA2 -AES.
Would this be the recommended solution? If not, what is the best way?
Cory
George Stefanick
Enable WPA2 PSK on the WLAN for a simple config. Or go more secure and enable EAP since you have a radius server.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Amjad Abdullah
You can add WPA2-AES either personal or enterprise.
Just configure the WLAN on the WLC with WPA config and config same exact configuraotin on WGB. that is it.
Amjad
Rating useful replies is more useful than saying "Thank you"
