194
Contributor
1111 WLAN Controller
Is it possible to turn off the status lights on wireless access points that are connected to the 1111 WLAN controller? I was looking for the option, but I do not see it listed.
Alex
Everyone's tags (6)
1 ACCEPTED SOLUTION
Highlighted
Contributor
Re: 1111 WLAN Controller
You can do it from the 1111 SSH CLI. You can do it by AP or all of them per below example.
>config ap led-state disable all
1 REPLY 1
Highlighted
Contributor
Content for Community-Ad
August's Community Spotlight Awards
