1131AG AP with Cisco 5508 Controller Lighting Issue
I had deployed Fifty 1131AG AP with Cisco 5508 Controller, the problem is some APs giving a orange ligth and some of them didn't flashing "there Led is Off" , Have you any idea about this issue , any suggestion is welcome
Stephen Rodriguez
You can try the cli command to turn the lights on.
Config ap led -state enable all
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
8 Replies 8
Stephen Rodriguez
HTH,
Steve
Dear Stephen , Thanks for ur Feedback just i hope know if I Can try  this command from Controller CLI ??
Yes controller cli
HTH,
Steve
I'll try it and come back for you .
Leo Laohoo
This is a known issue/bug.  As what Steve mentioned, enter the command "config ap led enable all" will fix it.
SHIBI V DEV
Just console to access point and see, what log you are getting while access point trying to join to controller. May be some IOS version mismatch.
Abhishek Abhishek
Hello Khadija,
As per your query i can suggest you the following solution-
You need to console the access-point and cli to see the logs and their indications.
For knowing more about color indications in AP please refer to this link-
http://www.cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_c4.html
Hope this will help you.
Thanks you all , and special Thanks to  Stephen Rodriguez , I  had just  test your solution today and it's working All my APs now are lighting many thanks
